Ibex Perf Cutter blade info please?
http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=20348
Author:  Frei [ Mon Jan 05, 2009 11:14 pm ]
Post subject:  Ibex Perf Cutter blade info please?
I have a German style bronze perfling cutter, but the 2 blades are center sharpened, not single bevel, and I don't have a grinder, so I was thinking just replace with Ibex blades. Does anyone know the width and if they are single bevel? Thanks
Author:  DYeager [ Tue Jan 06, 2009 9:11 am ]
Post subject:  Re: Ibex Perf Cutter blade info please?
Unless someone's been purfling an aluminum-bodied instrument, the cutters shouldn't be too dull. Perhaps you could hand-grind, either with sharpening stones you already own, or with sandpaper, or with a belt sander? Just try to take off the bare minumum, while following the original profile as carefully as possible. Did you test the blade to see if a file will cut it? Probably too hard, but you never know.
Dan
Author:  Alexandru Marian [ Tue Jan 06, 2009 12:28 pm ]
You can buy separate blade from LMI. They are good steel (I think they say they are made by Hock), and cheap. Dimensions are 33 x 5 x 1.4 mm - I hope they fit. One face flat, the other 2 bevels. They will work better if you sharpen and hone them once in a while.
Author:  Frei [ Tue Jan 06, 2009 3:00 pm ]
I would have to grind off like 5/16 of bevel to get it level, with 100 grit or something.
Alexandrew, is the "5" -5 mm wide? Length and thickness don't matter too much.
Author:  Alexandru Marian [ Tue Jan 06, 2009 3:03 pm ]
Yes 5mm
